Re: what does it mean when they say running "too lean" or "too ri
rolmops is correct about "rich" and "lean" generally referring to fuel/air mixture, although occasionally some people use the same terminology regarding oil/fuel.<br /><br />Most newer motors do NOT have adjustable mixtures, but have fixed low and high speed fuel metering jets. Usual causes of bad mixtures are carb float valves and junk in the carb. Fuel left for long periods of time (i.e. > one year and outdoors) is a primary cause of crap in carbs along with contaminated fuel (water and debris, rust, etc.).
