Re: What does a miss sound like?
It sounds like...<br />BrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrBLIKrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrBLIKrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr...<br />Or something like that. Use your imagination.<br /><br />A miss is generally an intermittent problem with the ignition - a sudden, quick burble in the normal operation of the motor. It can be rapid fire or only occur once or twice during a cruise. Can be a failing plug, bad ground, failing brainbox, worn stator, etc. Bottom line is that they can be a real pain to diagnose...<br />- Scott
