Re: What do you think? Inboard or outboard?
Straight inboard has better weight distribution,<br />generally will track better at docking speeds,<br />is difficult to steer in reverse generally not as responsive steering at docking speed.trimming<br />is not as good and requires tabs.It generally doesnt bound around as much as either of the others.<br /> An IO is very manuverable,very tail heavy,<br />usually wanders at slow speeds,generally slower to plane than a straight inboard,more complicated to maintain.trimming the boat is easier.<br /> Outboard is very manuverable somewhat tail heavy,<br /> wanders a little less than an IO,planes guicker than an IO,is easier to maintain is a little more limited on HP than either of the others.Outboard has the obvious advantage of an easy motor change.Of course both the IO and outboard can be tipped up for beaching etc.<br /> I prefer the straight inboard overall, although the both of the others are more easy to handle.
