what do you guys think
miloman
Hey there been away for too long. Ok here is my question my friend has an 84 18 hp merc. It starts fine cold trolls fine cold and WOT fine cool. Once it seems to heat up there is a drop in speed as he says it seems like hes losing power and has dropped a cylinder. Then the problem will resolve itself and off he goes until it happens again. He has said that the cord had become a bit tougher to pull once the engine heats up. Pulled the plugs changed them but now he says it makes a "crackle sound" I think that sound is unrelated as the plugs might not be gapped right. Anyway Im thinking coils hes thinking stator what do you think? What diagnostics can be done to determine it. I asked if it was a fuel delivery issue. He said a marina checked it and said it was either coils or stator. Good buddy but sorely poor on cash. I figured Id ask my guru friends here so what do you think.
achris
More fish than mountain goat
Re: what do you guys think
You got a difficult one to do a 'over then net' diag on. But, have you thought about a partial sieze? As the pistons heat up they could be grabbing on the cylinder walls.<br /><br />Just a thought.<br /><br />Chris..............
WillyBWright
Definately with achris on this one. Once upon a time that motor overheated and fused some of the piston aluminum to the cylinder wall(s). Check the gearlube, though. Similar problems could lie there. If it is losing spark on one cylinder, that's easy to check with an inductive timing light. If the sparkplug sparks, the light flashes. Check both plug leads when the problem shows it's ugly face. Despite the pricey ignition components, they're still cheaper than an overhaul.
miloman
ok an update there is no spark on either plug what do you think now
ronmold
Switchbox, they will go intermittent then just die
BassMan31
Im thinkin coil guys as you have no spark. Is the engine actually dieing?
miloman
looks like an intermittent spark on again off again im thinking stator
