What do you call it?
jmist
I have a Indmar engine 350 Fuel injected, what is the name for the unit that cools the fuel where the fuel pump is housed in and does anyone know if these can be recondition or where I can get one. It seems like there is a leak inside the unit when the fuel pump is turned on, gas comes out of the exhaust port. This is without the engine running and a water hose hooked up for cooling.
dick
Re: What do you call it?
Vapor separator ,and there is a float inside of it that maybe stuck open. Can you see the screws around the top that hold the cover down? ,and by exhaust do you mean the vent from the vapor sep. ? or out the back of the boat ?
jmist
The gas is going out the exhaust ports on the back of the boat. Do you know if this can be repaired or replaced, thanks for the feed back.
Walt T
Let me see if I have this right, You turn the key on and liquid gasoline comes out the exhaust pipes in the back of the boat?<br />If so, then gas is getting into your cooling system via the cooler, and the water carries it out the pipes. Replace it.
