What do need to swap from Thru prop to Thru hull exhaust
sinfuse
i have a 210 baja with 5.7 merc.... where can i get the parts needed to change from thru prop to thru hull exhaust... is this a hard job... what kind of cost am i looking at??? any suggestions would be GREATLY appreciated !!!! oh yeah its a alpha I outdrive if that matters
flashback
Re: What do need to swap from Thru prop to Thru hull exhaust
Try this: http://www.corsaperf.com they are probably the cadillac of thru hull exhaust, very expensive especially the captains call system which allows you to have it both ways.......good luck.
Mufasa
Unless you can pull the engine and remove the Y-pipe to install the block off plate where the exhaust exits you should go with the silent choice set-up. There may be times when you want it quiet. The part that gets hard is where the thru hull tip exits the hull. It is often not flat and hole needs to be elliptical, this requires some filing to get the right fit.
