What do I have???
ripped_78
rbh
Re: What do I have???
Please resize your pictures, they're huge!!!!
bomar76
1.Heat exchangers (water to water radiators) for your closed cooling system (engines have antifreeze in them...or should)
2.Not really.
3.Riser to manifold joint is leaking really badly in one of the pics. Possible serious issue there. I'd pull them all and cheack right away if you wish to avoid water in your engines. One of the engines has had the risers replaced as they don't match....so someone had a problem at one time.
ripped_78
I din't realize this is a closed cooling system. Should there be any water coming out of the exhaust?
bomar76
Yes. It's the water that cools the heat exchanger and the exhaust.
ripped_78
That does make sense. I have a sPare gasket kit for the riser is there anything specific I need to look for?
bomar76
The mating surfaces rotted and rusted away, the manifolds and risers themselves rotted away inside.
