boltonranger
- May 2, 2004
- 204
Ok; so here it is.
Rolled out the boat and put it on the muffs to run the motor and check things out.
About 18 months ago I replaced the water pump seals but haven't been on the water since.
So there I am - water pressure at the muffs and after checking all the fluid levels
(Closed coolant system was full, yay.)
I crank it over and it starts.
A little shaky at first, always has been.
Smooths out some and it seems a little loud.
I shut it down and hop out.
Water's on alright.
OK so I hop back in and fire her up again. This time I see water running from the motor box towards the bow!
So I kill the engine and raise the motor cover.
Hmmmm.
Ah! There it is.
I failed to re-attach the lower portion of the oil cooler hose to the freshwater HEX outlet.
I usually don't drain the cooler - but for some reason I had done it many months ago.
So I attach the hose and clamp it.
Start the engine warily.
All good.
Ran on the muffs fine etc.
Never overheated - temp was normal.
So after this incident I began thinking...
Is there anything else I should check?
The boat probably ran less than 2 minutes without the hose on there - that's not to say the hose and hex weren't somewhat lined up -my realization of it all
happened so quickly that I can't recall for sure how well or not well they aligned;
IOW whether water was actually making it to the exhaust elbow or not.
Just can't recall for sure. I do know there was water at the impeller. That's certain.
Soooo... what should I check now?
Bear in mind I did run it for some time after I attached the hose.
Exhaust water generally came out the left and right sides of the out drive and a small amount out the prop.
It all seemed normal; just thought I'd pass it by you folks and see what you thought.
Thanks in advance;
-br
Water's on alright.
Hmmmm.
Ah! There it is.
All good.
Thanks in advance;
-br
