I am familiar with what a fouled plug looks like in a car engine because it is not supposed to burn oil, but what does a fouled sparkplug look like on a 2 stroke engine? <br /><br />Is anyone familiar with the wiring on a COBIA boat? I removed my faria tachometer and now need to reinstall it. I misplaced (lost) my diagram of the wiring connections. I have three posts that need the loose wires. There are two black wires, two purple ones and a single gray wire. I feel certain the black goes to ground, but which goes to signal/sender and battery? Also, what is the pulse setting for this tach? I have it set at 6 which works better than the 5 that it was set at factory. The motor is a Yamaha 150 1998 without oil injection if that matters. Whenever I trim the motor the tach will respond with what I call a crazy needle and then return to where it seems it should be.
