eavega
- Apr 29, 2008
- 1,377
I have (had) a 1972 50 HP Evinrude Model 50273C. Compression, checked, 125 dead even on both cylinders. Spark, check. Fuel, check - from tank to carb. pump the bulb until needle valve closed off fuel to the carbs. Timing, checked at 20 degrees WOT (Spec is 19 degrees +- 1). Temperature, check. You could lay a hand on the cylinder, 120 degrees by non-contact thermometer after 5 min WOT running. water dumping over exhaust ports as expected. fuel mix 50:1. Motor running 5500-6000 RPM which is its operating range per the manual (Manual says 5000-6000 RPM). Today, on its fourth trip out, it blew a hole in the cylinder block. Engine is toast. I was able to limp back to the dock on one cylinder. I could see exhaust leaking through the breach in the cylinder block. I don't even feel like tearing the motor apart to see what damage there was to the piston, rods, etc. Now I have to go and part this motor out to build up a budget to re-power my boat. My question; what did I do wrong here? Why did this engine fail? Granted, I had just purchased this motor a year ago, and had to take the word of the previous owner that it was maintained, but I tore into it and found that they carb gaskets were all new, the impeller was in good shape, so I had no reason to doubt that the motor was not maintained.
It is just so frustrating. I have worked for the last 4 months every evening to make sure the hull was in good shape (I had verified the working condition of the motor before I began the hull work), just to have the engine fail on me on its 4th outing. I'm back to square one now. Hopefully I can sell the valuable parts of this motor (the controls and the lower unit, since it is a hydro-electric shift, and the starter, ignition system etc) for at least enough to get me onto another motor that may stand the test of time.
This is in part a vent post, but also a question as to what I could have done to prevent this catastrophic failure of the motor.
Rgds
Eric
Rgds
Eric
