eavega
- Apr 29, 2008
- 1,377
Hello all...
So, this is a follow-up to a question I posted on the Outboard Motors thread. For a quick synopsis of that: I have a Valco 14' aluminum v-hull boat, and given the age of the hull (~50 yrs) and my budget, I tried to power it with an old 10 HP seahorse. I found this setup woefully underpowered and wondered if there was something wrong with the motor. The responses I got on that thread basically boiled down to 1. get the weight distributed correctly on the boat so it was not stern-heavy, and 2. I was right on the cusp of what it would take to get that boat to plane. The boat is rated for 25 HP max, and someone there told me the rule of thumb was 50% of the max rating is needed to plane the boat.
I have since looked at other aluminum v-hull fishing boats, and found that although the construction looks almost identical to my boat, A lot of them are rated for much smaller motors and weight (usually in the 10-15 HP range, with max weight of 500-600 Lbs). This is probably why I was told by everyone that a 10 HP motor should be fine on my boat.
So, my question is; what actually determines the max HP (and weight) of a boat? Is it materials, construction, design, etc? About the only real difference with my boat and other similar boats is that it is a bit wider across the transom than some others.
I was just curious, because the cost of another boat of this size, and the cost of a bigger outboard motor is roughly equivalent, and I was trying to decide which route to take.
Rgds
Eric
Rgds
Eric
