Let me start by saying I know that what I did was stupid....I should have understood how my motor is cooled before I went on the water!
I overheated my 1997 Volvo 7.4L (454) and was wondering what kind of damage I should look for? The engine is RWC and has new risers/manifolds.
A couple of months ago I was cruising in the sound and the engine alarm went off. I immediately looked at the temp gauge and saw it was around 220 and I shut it down. I opened the hatch and saw that I had broke a belt on the front of the engine. The belt was to the alternator and to the engine water pump (not the raw water impeller). At this point I got stupid. Stupid me thought only the alternator was affected thinking the raw water impeller supplied all cooling to the engine. (I didn't think about the engine having a water pump). Anyway, I let the engine cool down and I started it up. It ran fine for a few minutes (the risers were cool) and started overheating again. I shut down and repeated this cycle several times until I made it in. I assume I was able to do this because the raw water pump was pushing enough water into the engine to keep it relatively cool.
Since then I have not had a chance to put the boat back in the water but I have replaced all the belts and the thermostat. I will be off for almost two weks over Christmas so I want to run the boat. The engine starts and runs fine "on the hose"; however, before I put it in the water is there anything I should look for? I assume I should do a compression check. What else should be checked (and how do I check it)?
Thank you.
Thank you.
