Re: what causes the buzzer to go off on a 1996 yamah 115 two stroke
I'm not really familiar with that motor, but I have dealt with some fuel problems. Do you run ethanol or non-ethanol fuel? Ethanol fuel will clean the crud out of your tank, lines, filter,etc... and despite the filter it can wind up in your carbs clogging up the jets. What I suggest is to eliminate the problems or probable causes with your fuel system. When I had my problem (hard starting, bogging, lack of power) I compleatly went thru my fuel system. I pulled the tank and cleaned it, replaced all fuel line from the tank to the engine and evan the the ones under the cowling, replaced all fuel/water seperators and filters and had the carbs cleaned and rebuilt. I have not had a fuel issue since and this is something I have done with the last 3 boats I've owned. Also I began using the marine stabil and I will not let ethanol fuel sit in my tanks for longer than 2 months. I know it sound kind of drastic, but with all the rumors, good and bad about ethanol fuel I figured I'd rather eliminate that as a potential problem than deal with issues cropping up constantly. Look at it this way, aside from some labor on your part (fuel tank), replacing hoses and filters is relatively cheap and the bigest cost is getting the carbs done which is usually around $100, but once this is done it will compleatly eliminate the fuel system as a source of trouble and you will have allot more piece of mind. I see allot of people in this forum with fuel problems and it just seams to me that if they would just take that extra step they could be done with it ya know, instead of going nuts trying to track down which hose, or what filter, or is it my tank causing the problem. It may or may not be the cause of your problem, but I think it's still very worthwhile to do. Just my 2 cents man and I hope ya get her figured out. Luck too ya.
Art
