what causes overheating after replacing the old impeller with a new impeller?
I just replaced the old impeller on my Yamaha 200Hp outboard motor & put in a new one. I had it running for 15 minutes working perfectly well and after the first 20 minutes, it started to overheat. What are the main causes for it to overheat? You Can Contact me at my email if you'd like at lorenzomalagon@live.com
99yam40
Re: what causes overheating after replacing the old impeller with a new impeller?
Check/replace the thermostat and PRV
Where can i find the thermostat & prv on a 1988 200Hp yamaha outboard motor?
Scoward
I Have an 87 200 HP Yamaha with out a temp. gauge. I also did the whole water pump rebuild this year. Everything appears to working fine but what is the best way to know what temp. I'm running at?
Captn Dave
Infrared gun on the heads
