DaffyJeffy
Thread starter- Joined
- May 28, 2015
- 57
So I got a boat trailer just like this one for free at a job I did.
It only had one tire and wheel but did have both hubs. There wasn't much left of the bearings and most of them where missing (maybe someone started to change them at one point?)
Anyway, I don't know what bearing kit I'm supposed to get. Here's what the dimensions on the axle.
The hubs are the same diameter on the inside and outside (about 1.975"). It looks to me like the inner bearing should have a larger inside diameter (than the outside bearing) and the seal presses against the "step" to the square portion of the axle? It also appears that the number on one of the bearings is L44649.
I'd really appreciate help in what bearings to get. Although I have changed utility trailer bearings before and I'm very capable mechanically, I just don't know what bearing kit to buy.
It only had one tire and wheel but did have both hubs. There wasn't much left of the bearings and most of them where missing (maybe someone started to change them at one point?) Anyway, I don't know what bearing kit I'm supposed to get. Here's what the dimensions on the axle.
