what auxiliary size
kiwi karl
hi this is a great site.<br />I just have a question about what size motor to run as a auxiliary.<br />my boat is a 14.6 sea nymph with a 90hp v4.<br />any help would be great. <br />thanks
JB
Re: what auxiliary size
Hi, Karl.<br /><br />Welcome to iboats. :) <br /><br />What would you need the aux engine to do?<br /><br />In sheltered water, as a "get home" engine I think as little as 6-8HP would do fine.<br /><br />But if you would need to overcome strong currents or winds and maintain steerage in rough water 15HP would be a lot better.<br /><br />Good luck. :)
JasonJ
I have a 5.5 horse kicker on a 16.5 foot boat. It manuevers fine in any wind and water conditions, but I use it for trolling. I am not concerned if it pushes the boat faster than 2-3 mph, but if I ever had to get home with it, I would be there for a long time. Like JB said, it depends on what you will use it for. I prefer a smaller kicker working higher in its rpm range for fishing (mine is running a bit over 1/2 throttle to give me 2 mph). If it is primarily for getting the boat home, go for as large a kicker as a mounting bracket will allow (most are limited to 100 lbs). Good luck....
kiwi karl
thanks for the advice,it would mainly be for getting me home.since our water condition down here in NZ are very unpredictable i'll better look for 8 to 15hp.<br />thank again<br />karl
youngboater
I have an 8 on my 16.5 Lund and on GPS my top speed is 5.5MPH. You might look a little higher than 8 but I don't know the conditions there and I'm not familiar with Sea Nymph.
