JarFisch
- Jun 28, 2010
- 14
I'm suspecting an intermittent powerpack spark dropout --- this despite OK DMM & DVA cranking tests..(?)
Working on a 1973 115hp V4. Recently got it running after sitting for several years, but now having variable rpms changes at idle & low-to-modest throttle speeds.
I'm happy to provide detailed info on work done & test results.. however I thought I'd get right to the main question rather than dump out a bunch of wordy details until asked or needed.
So here's really the question I'm wishing to ask:
Is it possible that an older (1973-1977 CD4) powerpack may appear to check out OK via typical DMM & DVA tests at cranking speeds (plugs-removed; fresh battery)...but might then might also irregularly drop spark on one (or more) cylinders while either at idle or low-to-mid running speeds?
Thanks,
Charlie
Thanks,
Charlie
