Re: Whale Tail Thoughts
This is the response I got back from permatrim when I asked the difference between hydrofoils and their product:<br /><br />The permatrim works differently to the Stingray , doelfin and SE 300 hydrofoils, by using the water that comes of the top of the propeller (the<br />hump you get out the back of the motor) and holding that down so you get more lift and thrust from the same amount of power.The other brands work like a aircraft wing, where the water rushing over them gives you lift.<br /><br />The tests done in NZ & Australia rate the permatrim with more lift and better performance all round.A good test done over here was when the water taxi's where using the SE 300 sport and still couldn't get on the plane when fully loaded with passengers, then we fitted a permatrim and they planed easily, they said that they payed for themselves within a week. The taxis are 28 foot rigid inflatables running single 200hp yamahas, carry 16 people.<br /><br />They are also stronger and more durable and can be used for a step.<br /><br />If you need any more info please email me at<br />permatrim@nznet.gen.nz
