I have a West Bend 7.5 Hp circa 1962 with no spark. The nameplate says it is a model 7202, S/N 1156 and that it was made in Barrie, Ontario. Simpsons Sears sold these in Canada; I have an old 1965 catalog showing these outboards but under the Elgin Fisherman name. This motor was stored for about 20 years. I?m restoring it for a Glen-L hydroplane I?m making for my son. Nice light engine, used to run really well.
I don?t get spark from either plug (H-8J) and tried new substitutes (RH12) no difference.
I pulled (finally) the flywheel and everything under there looks in mint condition. The engine likely has less than 150 hours. I measure the primary coil resistances at about 0.6 ohms (after subtracting the meter offset of 0.3 ohms), and I can see this drop to almost zero when the points close. The secondary on each coil is 5300 ohms from the spark plug boot to the ground. I pulled one coil off its E shaped core and it looked perfect, no cracks or discoloration.
The condensers (Wico X11397) measure 0.22uF on a capacitance meter when removed from the magneto plate. I also measured them with a high-R meter and can see them increase in resistance for a second or so until they go over range so it looks like they are OK.
The 2 pole magnet in the flywheel has lots of pull against steel, and although I can?t see the gap between the coil laminations and magnets directly, it appears to be very small.
I removed, cleaned, and reset the points to 0.020 as marked on the magneto plate although the points looked almost perfect with no peaks or fry zones.
I don?t see anything else to look at or check. The only component common to both circuits is the magnet.
BTW great application note from Fluke (electrical meter folks) ?Troubleshooting Outboard Motor Magneto Ignitions? from their site. Kudos to them.
