Hudsons dad
- Nov 7, 2011
- 3
Hi, new to forum and was wondering if anyone knows where I can get a wiring diagram for a 2004 22' coastal cuddy cabin. Here's the problem; bought the boat used and apparently at some point both the aft bilge pump and float switch were replaced. When they were replaced some wires were cut and pulled so, I can't tell how they were original wired. Both the pump and switch test as working, hot wired the pump and checked the switch but, I can't manually activate the pump using the dashboard switch and the float switch doesn't activate the pump either. I'm at a total loss here. Appreciate any help, thanks!
