hullofalottatrouble
- Jul 16, 2005
- 306
this will be long but want to give as much detail as possible.. <br /><br />have a 1982 mercruiser 260 with I-drive <br /><br />had boat out a few weeks back ran fine for 1-2 hours then started to overheat.. or at least thats the way i remember it..<br /><br />took it out next day to check on things and ran hot again.. while it was out the shift cable gave out.. wouldnt engage into forward.. finally got it to engage and engine was running really rough.. stalled when throttled up or down.. ran enough to get back to ramp and stalled when throttle down at ramp.. <br /><br />took boat to shop.. they said bought ran fine for 1 hr on trailer and hose and didnt see any over heat problem.. did a tune up and replaced a water hose.. also mentioned there was no thermostat.. <br /><br />i replaced the shift cable.. took boat out again and under load as I was moving out of the harbor heat started to slowly creep up.. temp got to about 210 as the temp crept up the engine labored and felt like it was missing and stalled.. drifted around to let engine cool.. start again.. soon as it got into gear it died.. tried a few times did the same thing.. engine was about 190.. when engine got back down to 160 again.. started right up.. went into gear ran fine.. engine got hot again 210 ish again slowly started to labor and stalled.. got towed into ramp.. <br /><br />engine heats up to 160 at idle when on ramp and stays there at idle.. <br /><br />is this a water pump/impeller issue or possible a more serious engine problem? <br /><br />Thanks <br />Rob
