Bay Stealth
- Dec 30, 2004
- 15
I've had my boat for about 5 years, it is a 21' center console bay fishing boat. It has a 1996 Yamaha 150 outboard on it. I've never had any trailering issues with it. I hadn't had the boat out in about 4 months until last Sunday. When we were headed down to our fishing spot a guy on the highway pulls up flashing his lights and yelled out the window that my prop was dragging the road,,,I quickly pull over and find the motor all the way down and the transom saver still attached to the motor but draggin the ground, it is ground down to resemble a spear. This saver came with the boat so I attributed the problem to the saver itself failing. It is the type that leans on the rear roller. We went ahead and put it up on the factory tabs and took off. It rode fine the rest of the way and back home but the factory locks were bent out a little bit. I went ahead and bought a new transom saver at Academy, put it on like I have for the past 5 years and took off down the road today. Check it a little ways down the road and same thing as the week before, motor was in down position and the saver was ground off. Now I'm thinking its something with the Tilt/Trim mechanism? Somehow I think the motor is bouncing up and down and coming detached from the roller and then the weight of the motor pushing back on the hydraulics. I once again put it on the factory locks and on the way home it came down again. The factory locks are pretty well bent up,,,its real puzzling to me since I've never had an issue with the motor doing this.
Does anyone have any insight into this? Thanks,,,I'm lucky so far its only scraped the skeg and prop just a little bit but I don't wanna leave a trail of lower unit parts all over SE Texas!
Thanks in advance!
Thanks in advance!
