I have a 1985 140 Johnson. Its has a weird firing issue on cylinder #2. See video link. When I start the motor it idles good. After a few seconds it starts popping through the exhaust. But when I pull the #2 plug wire off it quits popping and idles pretty good again. Here's the rundown of what I have tried. First off I tried a coil, plug wire and spark plug off another cylinder and didnt change nothing. I rebuilt the carb on that cylinder because I found a leaking gasket. No change. I have put a new stator, rectifier and power pack. The motor has between 125-132 compression on cylinders. The motor runs.good.on top end but is a little slow getting on plan. My question is could the timer base be bad. What tells the spark plug when to fire on an outboard ?Its seems to me like the plug is firing when the piston is in the wrong place and combustion is going directly out the exhaust port. Is that possible ? I'm new to outboards and learning as I go. Also I noticed that the port side head (#2 and #4 cylinder) doesn't feel quite as hot as starboard side head. Could it be temperature related ? I feel like the spark plug is firing at the wrong time in relation to piston location.
