weird assessory
ondarvr
Re: weird assessory
It protects the prop from rocks, logs and to a lesser extent possibly your leg, foot or hand.
It also helps with downrigger cables and fishing line.
TOHATSU GURU
Re: weird assessory
We call them manatee scoops. As you run along in the water they slice out fillets from their backs. Also works on downed divers, water skiers and PWC morons.
Chris1956
Re: weird assessory
OMC experimented with Prop Guards, but found that they created a lot of drag. I expect they are good for certain applications.
j_martin
Re: weird assessory
They've been trying to idiot proof props for years.
The problem is that idiots are too ingenious.
ondarvr
Re: weird assessory
The type pictured is normally used on small OBs where the primary use is trolling.
