Re: Weight of Vmax 150 Yamaha?
>...changing out my 1986 Merc 115<br />>I was comparing weight. That is getting up there.<br />Hi Ron Davis,<br />If you want more horsepower than your 1986 Mercury 115 and 4-stroke is no problem you may want to check out the Suzuki DF 140 (140 hp) since it weight only 410 lbs (186 kg) and that is even lighter then any 115 hp 4-stroke, except Mercury 115 EFI that weight 386 lbs (175 kg). The Suzuki DF 140 will not have the brutal force of for example Yamaha 150 2.6L V MAX HPDI but may be enought for your boat and needs?<br />/Bo
