Re: Weed Cutter for OB prop
If you fail to find that product, you might try finding another two blade prop (assuming that's what you have now) and either having a prop shop or machine shop (or yourself) sharpen the leading edge to a knife edge. A prop shop could also put a little more rake on the blades. While this would probably alter the WOT performance of the prop, it might help you out in the weeds. If your engine has a three blade prop you might try to find a two blade that would either work or be modified to work. I've also seen "V" or cone shaped affairs that bolt to the lower unit to deflect weeds around the prop. Its been many years ago though.
