Re: Weak spark on 1977 Evinrude 75hp
Is it still throwing a 7/16" spark?
It could be other things, y'know. How about arcing out at the plug boot? How about a bad spark plug? And the most serious dread of all dreads, is it ingesting water into a cylinder or cylinders? Those 3 cylinder loopers are bad about that.
Not sure if it was exactly 7/16ths cause the spark tester doesn't have a ruler on it...I just ballparked it. Even when I shortened the gap to see if spark improved spark was what I call 'impressive' on any of the 3 cyls. I didn't 'snap' much either.
Out of curiosity, I went over and checked the quality of spark on my neighbor's '69 Johnson 55hp. His motor runs on a single coil w/ amplifier instead of powerpack, but the coil looks like my coils...but with a screw-in connection. Part numbers are close....0502882 vs. 0502886.
His spark was white and 'snapped'.
Ingesting water? What would cause that? And what are the symptoms of water ingestion?
If you read the initial thread on started on my motor, I had couple hiccups(they were like quick 'misses' or hesitations) when I splashed the boat for the first time a few days ago. They were very quick 'misses' and went away. Other than that the motor ran great for the 30 mins or so we ran it. Ran it at WOT for about 30mins cruising around and had no problems.
Update: Pulled the plugs to see if pistons looked "steam cleaned"(evidence of water ingestion). Top 2 holes have oily film on them. The oil still looks wet. The bottom hole is clean, exactly but I don't know exactly how 'clean' a piston would look if water was getting in there.
I'll pull the head if it's necessary, but don't want to do it just for the heck of it.
