bronxlatetour
- Jun 16, 2006
- 77
I have a 1990 sea ray 250DA with the 7.4 Bravo serial#OD 376979. Last time I ran the boat aprox 1 week ago, it ran beautifully. I took it out today and wouldn't start. I lifted the merc cover off af the carb and noticed a few strange things. First, the wire from the coil was disconected. There was a black oily substance on the underside of the cover above where the coil is. This same substance was inside of the top of the coil where the wire plugs in. I cleaned it out and cleaned the wire and reconnected. No good. Next I tried putting the wire next to a ground and cranked it, very little spark. Battery power is fine and I'm getting fuel. There is an excellant chance my boat was struck by lightning while sitting in my driveway. Is it possible that this could have fried my coil or something else? As I said, I'm getting a spark but very weak and not as fast as usual if I tested it. Thanks in advance for the suggestions.
