Weak spark at dist cap .
terrasdad9933
Compression at 160 PSI New cap & rotor, ing in cap . Will crank and run at low RPM and bog and sputter when gassed I am auto mechanic of over 50 years. at dist cap hold terminal and spark is weak and no jump WEAK! Mercruiser 140 HP In Out . Put on also new coil .and plugs.
wellcraft-classic210
Master Chief Petty Officer
Hi
Year and type of engine?
Is it points or solid state?
Has any one verified Voltage at coil and a good connection to GND ?
Are you sure its not fuel related ? clogged fuel filter etc ?
Ayuh,..... Welcome Aboard,..... What vintage 140 hp,..?? they've been around for many decades,.......
