Does anybody know how to figure out whats causing the weak spark? I need ohm and voltage figures for each part and wire. Bought a book, says take it to your nearest dealer. Some help there. Motor ran fine then my brother let it sit in the water a couple of months. Went to pull it out and there was no spark. I took the trigger box in the house overnight. Hooked it back up next day now I have enough spark to jump a 1/4 in. But still not enough to make the engine fire. We took the boat to the dealer and they said it needed an overhaul, $1800, because 2 cylinders were lower in compression than the rest. They have 105 lbs vs. 135. But I think this is cause it was sitting and that it might come back if we can get it to fire. I beleive it should run even if those 2 cylinders were bad. (they do come up with some deep creep sprayed in the plug hole)<br /><br />This motor has a thunderbolt II ignition. Single coil, distributor with electronic trigger-not points, and trigger box.
