I have a 2006 40hp 3 clynder yamaha outborad motor and it was working fine up until yesterday when it started to rough idle going down to 700 and then up to around 1200 ,I decided to take out the carbs and clean them out , the bottom carb had some black particles on the bowl when I opned it up and I did notice that the float was sticking ( could this be the problem that I need a carb kit ) well any way point is I cleaned them out and put them back on turned on the engine in a tank of water it worked fine rpm"s 1100 when idling bit rough but ok . I decided to take it out to the lake and try it out it worked fine for about 25 minutes runing full throttle at 5000 rpm's then all of a sudden the rpm's at full throttle dropped to 3000 and would not go up past that I cut of the engine and restarted it but the rpm's would not go past 3000. Can somebody out there please help me out . Thanks in advance.
