I got into some trouble with my small Suzuki DF9.9. It had no pee stream so I tried blasting it out with some compressed air. There was a rubber nipple which I seem to have blasted into the motor, the nipple is gone. I opened the motor and found there is no hose on the inside, the pee stream is somehow built in to the "middle" unit (not sure what to call this, its the part the lower unit bolts on to. The whole thing is bolted up and looks sealed I don't wont to open it without a repair manual.
So, I ran the motor it seems to run ok. I tiny amount of water is spitting out of where the nipple used to be, and a lot of hot exhuast gass. Not hot enough to burn but definitely hot on the skin. And, there is water coming out of a small whole on the BACK of the middle unit, right above where the lower unit bolts on. All the water seems to be flowing and the motor is running ok, but not sure where the nipple went. I ran it about 5 minutes.
