weak flow/no overheat
scotty c
My 1999 Honda Bf50 runs like a top ,although<br />lately i have noticed the flow from the telltale<br />is weak.<br />in the past i have used compressed air back thru<br />the pee hose while motor is running and it <br />clears and starts to pee strong, but after a <br />number of attempts, no luck getting that strong<br />stream going.<br />the motor is not hot to the touch, and the overheat alarm has not gone off.<br />my first thought was the impeller needs replacing<br />but since no overheating, does not seem likely.<br /><br />What do you think ?
WillyBWright
Re: weak flow/no overheat
Sometimes a clog gets into the hose between the motor fitting and the pee fitting and just kinda bounces back and forth in the hose. Remove the hose at the motor end and then blow into the pee fitting. If that doesn't help, have a look at the pump.
scotty c
pulled the tube and blew compressed air into<br />the fitting. that cleared it and now it's<br />peeing like a race horse.<br /><br />thanks !
