Chris wrote in an other post:
Charlie, The copper water tube runs from the top of the water pump in the lower unit into the casting called the exhaust extension, which sits under the powerhead. it fits into a rubber seal in the exhaust extension. Make sure it is seated in the seal. You can put a garden hose on the end of the water tube and run the water on LOW pressure to make sure it circulates correctly. If so
My question is ..WHAT is the circuit ? have have the lower unit off ..the garden hose in the coper tube and the water goes up the head and back down the exaust ... should i have water comming out the pee hole?
and or the 2 hole in the midle of the leg just under the lower cowl it thinks its called
Thank
Jacques
Thank
Jacques
