Serial #2739070, I have tested in a bucket as well as muffs, it's a 50hp 500 thunderbolt motor. I had replaced the impeller as well as gaskets. Because the old impeller had been torn to bits, prior to the old impeller shredding it had squirted out fine when idling. I have ran the motor for around 5 minutes tops at idle and still nothing. The new impeller is still fully intact, when the motor is off of I spin the prop I can hear the impeller push the air like it should. I'm thinking it may be clogged somehow and if you guys agree, how would I unclog it? I've tried squirting water up the copper line and down the squirt hole.
