Water tube? Force 125
pastorbud
What are these things? They were on top of the leg when I pulled the powerhead off of my 125 hp force . They look like they connect the water tube to the powerhead. They're melted and were once round. I think I only need one. Looks like previous owner lost one in there.
pastorbud
Found one on another site. Mercury #816515
Now if I just knew where it goes and what it does. 😳
jerryjerry05
Called a stand tube.
.​It goes in the rear cover.
They really aren't needed.
They let the water in the cover when the motor is deep in the water.
gregmsr
I asked the same question a couple years back. I found mine melted floating around in there loose.
Took the time and effort to replace and re position, now they loose bouncing around again....
Like jerry said.....apparently not really needed.
pnwboat
I replace mine with some copper pipe many years ago. I believe it was 1/2 hard copper pipe. Measured the original plastic stand-offs. Cut the pipe to the correct length, including a threaded pipe fitting. Soldered on the standard threaded pipe fitting for 1/2" pipe. Bought the standard size pipe tap to match the threaded pipe fitting. Just so happens that the holes in the housing where the original plastic stand-offs are inserted is pretty close to the correct size for the tap. Tapped the holes, had to use a long extension to get the tap down to the holes. Pretty easy to tap since it's some type of aluminum alloy, use some WD-40 as lubricant. Just need to make sure you get the tap started straight. Inserted the copper pipe and screwed them in. Been working great like that for at least 7 or 8 years now.
pastorbud
Heh. Just ordered one, before the new info was posted. Parts diagram calls for two. I need..... zero. Thass how I roll.
pastorbud
I wondered about copper pipe. Also good ol' JB Weld. I'm putting a 150 hp powerhead on it and replacing motor mounts, so might as well do it up right while I'm in there.
pnwboat
I was going to order the plastic replacements too, but I figured that eventually they would break like mine did so I went with the copper pipe alternative. Well at least you know now. Good luck with your swap.
