Water temperature light on 40 HP vro 1989
Jimmyjak
I recently purchased this motor and it runs great. The second day the water temperature light came on. I checked the water tem coming out of the engine and it has a good stream with cool temperature so i check the top cylinder temperature by touch it is cool. From what i have read this usually means that the thermostat is stuck open or i have a loose or bad connection on the sensor. Am I correct or is it something different. Will it harm the motor?
Jimmyjak
My thermostat is stuck open is it safe to run for a season? I just bought it and don't have the money to put it in the shop. $0 hp 1989 VRO evenrude.
F_R
Honorary Supreme Mariner
8 year old thread. Put it back on the library shelf and start a new one.
F_R
From what I've heard, pilots are taught to always believe the gauges. If they say you are flying upside down, you probably are. As to your question, if it is getting hot, take it seriously because it absolutely will harm the engine. FYI, the telltale stream comes out before the water goes through the powerhead. Does not mean it is going on through.
GA_Boater
Welcome aboard, Jimmy.
Since you have this thread running about the Temp light, moved the posts about the thermostat from the old thread. The Temp light and thermostat kinda go hand and hand.
Take a look at the Help Tip on top of the page and hope you get her running cooler.
Bosunsmate
Might be stuck open thermostat.
You will need to open it up, you can do that yourself, its easy otherwise you risk serious engine damage and you will be spending a lot more on fuel as itl run very inefficently
Bosunsmate
Thanks hopefully i can free it up without damaging any gaskets.
Yes sure, i do that often. Gaskets arent too much if you buy them on line. You could also get something like permatex aviation form a gasket. It costs like six dollars and i use it to dress or the gaskets i use a second time around.
Clean out the channels why you are in there, good luck
boobie
It's about as hard on a motor to have it run to cool as to over heat. The thermostats were put in there for a reason.
