Water temperature alarm buzzer
Oldsaltydog
I am looking for a simple high water temperature alarm buzzer for a 1998 Force 90HP OB. So far I have not been able to locate anything, except the typical guages/senders and a unit for an I/O. Your suggestion would be appreciated. :)
DHPMARINE
Re: Water temperature alarm buzzer
O S D<br />I looked up your motor,and it shows a temp sensor.My guess it is located on the water cover/cylinder head.With a tan wire.<br /> Normally this wire would connect to an alarm in your remote control,or wiring harness under the dash.<br /> If you do not have an alarm(and I don't know enough about Force to guide you (where's Yoda when you need him),I would try an OMC alarm (buzzer).<br /> Tan goes to sender or sensor,purple is battery positive and black is battery negative.<br /> DHPMARINE
R.Johnson
Are you talking about the horn itself, or the sensor? Does'nt your force already have one?
