I am trying to connect a water temperature sensor (because I have a very nice gauge set, and I already installed the gauge on the dash), but I noticed that my head does not have a threaded hole. First question, I guess, is can I use one of the senders that bolts on to the head? It is a faria gauge...<br />Is the resistance range the same on all different water temp senders? (ie. can I use a teleflex sending unit) and if I were to drill and tap a hole in my cylinder head cover to fit a sender, where should I put it? Thanks in advance.
