Water Seperator
gvarney13
Good evening
Is it nessesary to have a Water Seperator on a 1987 GM 3.0? As of right now I dont have one but i am thinking of adding it.
Thanks in advance
WAVENBYE2
Re: Water Seperator
It sure wouldn't hurt, It's a lot cheaper to put on a fuel/water separator then it is to mess up your carb etc...I installed mine and it hardly took any time. Better to be safe than sorry.
billbayliner
Re: Water Seperator
Best inexpensive option you could add to the boat in my personal opinion. I think it is a must to avoid many issue that can arrise from bad / dirty gas.
When I bought my boat (96 bayliner with 3.0) I had (inherited) gas issues that plugged the ceramic filter in the pump and also the inlet filter in the carb.
I put the seperator / filter in and it was plugged solid to the point engine would not run and had to bypass filter to get home one night.
Replaced the filter and 3 years later still running like a champ with no fuel issues what so ever.
Bill
Re: Water Seperator
Ayuh,..... I Agree.......
Water in Boat Gas tends to be common,...........
More, or Better, or Bigger Fuel Filters are Always Good on a Boat........
