Water Seperating Fuel Filters for 2 Stroke Pre-Mix ?
phillnjack2
Ensign
Can anyone tell me if water seperating fuel filters are ok to use with 50-1 2 stroke pre-mix ?
You see ive taken off the vro:mad: (cannot trust it ,no way) but would still like to use a
water seperating fuel filter.
I like the ones with a clear bowl on the bottom and the filter canister above that you can
let any water or sediment out the bottom of the unit.
But i heard from someone that the 2 stroke oil might not go through the filters due to most being
between 10 and 20 microns etc.
I like the idea of the plastic housed one due to less corrosion in salt water enviroment that i
would often be using the boat in.
Is there any particular products to stay away from ?
or any products suited exactly for my pre-mix 2 stroke fuel.
phill.....:)
minuteman62-64
Re: Water Seperating Fuel Filters for 2 Stroke Pre-Mix ?
I've been using one for a year now w/no problems. It's one of the small Racor's (works fine for my 30 HP motor).
Solittle
I wouldn't run my engines without them.
minuteman62-64
I should have mentioned that my motor is a 2-stroke - no issue with the premix fuel and the 10 micron filter.
yep same here 2 stroke 40-1 pre mix and i pulled the water sep a few weeks back to replace it and it wasnt full of oil so the oil must be passing the filter
phillnjack2
Ensign
Thats good to know
i was hoping to hear replies like this.
so many adverts say for efi and all 4 strokes etc,
phill
Boss Hawg
Thats good to know
phill
Well, you've given me something to think about--
