I have a 2001 mercury 25 hp long shaft motor ..I wasnt satisfied with the amount of water coming out of the telltell so I decided to change the water pump .. this went off without a hitch and every thing went back together fine .. then I put the water muffs on and cranked the motor ..and there was a definate improvement in the amount of water coming out of the telltell.. but then I noticed that water was overflowing out of the midsection around the bottom transom swivle mount ..this is cold water even when the water coming out of the telltell is very warm ..which leads me to think it is not coming from up above ..the water dont seam to be under pressure .. this is the first time I have run it on a hose pipe ..so I dont know if this is normal or not ..I actually took the foot back down and looked again at the water tube seal on the water pump ..then I took the water tube out of the water pump seal and put it up in the power heat water tube seal first ..it felt good and stayed up in the seal I put it back together and it is still the same..can anyone tell me if I have a problem and what it might be if I do
