water pump
Holmstrom
i ordered an impeller and thought it would come with a gasket. Can a gasket be purchased separately from someplace or ? Ordered off ebay for a 70 hp chrysler. I read the sticky and it led me to believe there was s gasket that needed changed. should the impeller come with a gasket or just an impeller? I didnt see where iboats sold just the gasket .
Holmstrom
Re: water pump
Its a sierra part. Basically what im asking is was I wrong in thinking a gasket would be included in the package. You ask for what and from whom as if it made a difference . Some do some dont?
jerryjerry05
Re: water pump
He's asking for the year,model,serial#s.
They make about a thousand different applications for water pumps.
When you order an impeller,usually all you get is an impeller.
You get an impeller KIT and it can come with the gasket and a keyway.
Most Chrysler/Force pumps have a gasket under the wear plate.
Usually no need to replace unless it's destroyed when removing.
