Re: Water pump
Don,
I made a wee mistake on the sizing of the pins. It was early, and I was running on human memory.
The 3.5mm pin fits the clutch dog retainer in the LU.
The correct spring pins for the shift coupler are p/n 951403-0312, which are 3mm x 12mm, and cost $ 0.53 ea.
Spring pin tool A (to drive the 3mm pin out, has a stepped nose) p/n 345-72227-0, costs $ 26.63.
Spring pin tool B (to insert the pin in the coupler, has a cupped nose) p/n 345-72228-0, costs $ 21.35.
Nissan recommends using new pins every time you reattach the coupler. If you find that the coupler has been distorted from someone using the wrong pins, a replacement is: p/n 346-66241-1, costs $2.77
HTH,
