Re: water pump
not familiar with your motor but wrest assured that there is not much too it. generally you need to remove the bolts (usually frozen) that mount the L/U to the leg. you will need to disconnect the shift-shaft at the shift-shaft-coupler. on the only Suzie that i've worked on, the shift-shaft-coupler was behind a cover plate located on the top of the exhaust housing (leg) at the front of the motor,where the leg meats the power-head.<br /><br />it is STRONGLY suggested that you aquire a service manual if you plan on working on your motor. it will have all of the info you need for performing preocedures at home. (asfter market service manuals are available at the link located at the lower left corner of this page).<br /><br />Good Luck<br />HAVE FUN!
