water pump wooooooos
baitfish
have johnson 60hp...trying to replace water pump 4 the first time!!! have manual but it only says 2 remove 4 bolts & separate the gear case from exhaust.... i'v taken all bolts out including ones on trim tab.! but gear case & exhaust won't come appart????? is there a trick to this??please help!!!!
zzzzz
Re: water pump wooooooos
does the manual mention disconnecting the shift shaft ???? check under the carb for screw connector :cool:
baitfish
thanks a lot zzz. will check it out i'll tell u how i make out!!
