If you are selling it, you should replace the impeller and save yourself more trouble, if and when the buyer has questions or trouble with the motor. Giving the buyer copies of the sales receipts for all the parts that you put in the motor helps the sale of most all motors. When running motors in a barrel, the water should be at least 5" over the cavitation plate, and the motor should never be run over a fast idle as damage to the motor can be done. JMO
Oldman570[/QUOTE. How hard is it to change the impeller on a scale from 1 to 10 for someone who has a pretty handle on mechanical stuff? Also is it bad to haul an outboard on its back laying down for about 30 minutes?
