Im pretty new to owning a boat. I bought my first boat with a motor this past year. Its a used 2000 Tracker with a 90hp Mercury. Ive ran into my first real problem that I cant seem to figure out.
Last Sunday I took the boat out and quickly noticed the water was not pee'ing. I loaded back up and brought it home. I did some research on replacing the water pump as im mechanically inclined.
Today I swapped out the pump. Everything looked pretty normal, swap went pretty easy. Im confident I got everything in the right place. Keyway seemed to go back smooth. My question is when I hook up my water hose to the "mickey mouse ears" (dont know the proper term) should it be enough pressure to make the pump pee? I am able to easily blow through the hole, I cant seem to find any obstructions. Im just kinda stumped. The only other thing I know to do is put it in the lake and see how it works out.
Any help would be appreciated.
