Re: Water pump question.
The extra seals are for the OMC 400 or earlier drives, you don't need them. I guess they throw them all in there and sell the same kit for all models. I asked this question about a year ago. From what I remember, no one really knew. I figured it out though.
You will use two o-rings, the large one for the pump housing, a smaller one that will go inside the lower impeller shaft and the spline seal (not an o-ring but its in the kit, the one with the teeth to slide on water pump shaft).
