pabloescobedo96
- Feb 7, 2009
- 107
Hello, I have a 1979 johnson 35hp 35E79A.
The problem I am running into is the water pump kit # 0391631 contains a waterpump plate which has a smaller hole than the the one I removed. So which one is it supposed to have and could using the incorrect plate cause problems? And why do they give me 3 gaskets as opposed to the 2 I see? One above and one below the plate. 2 of the gaskets in the kit are the same.
I have attached a picture to show you what I'm looking at. Thanks for any imput.
Also I heard rumor I am supposed to silicone the the metal water pump case into the plastic housing?
